Cod 5 error
A vše kolem nich…
Edom
Cod 5 error
Příspěvek od Edom »
Zdravím, půjčil jsem si od kámoše hru CoD 5 a po spuštění mi to nahodí tuto chybu:
----- Initializing Renderer ----
execing ragdoll.cfg from disk
----- Client Initialization -----
----- Client Initialization Complete -----
Trying SMP acceleration...
...succeeded.
----- R_Init -----
Getting Direct3D 9 interface...
Pixel shader version is 3.0
Vertex shader version is 3.0
Shader model 2.0 code path is available.
Shader model 3.0 code path is available.
Using Shader model 3.0 code path because it is the best available path on this hardware.
Attempting 1024 x 768 fullscreen with 32 bpp at 60 hz
Game window successfully created.
Using 4x anti-aliasing
Creating Direct3D device...
Com_TouchMemory: 0 msec. Using sum: 0
Loading fastfile code_post_gfx
Loading fastfile ui
Loading fastfile common
Initializing render targets...
Requested frame buffer to be 24-bit color with 8-bit alpha
DirectX returned a frame buffer that is 24-bit color with 8-bit alpha
Initializing static model cache...
Initializing dynamic buffers...
Initializing particle cloud buffer...
Creating Direct3D queries...
Loading fastfile 'code_post_gfx'
used 1.13 MB memory in DB alloc
Setting initial state...
DirectX reports 256 MB of video memory and 1330 MB of available texture memory.
Using video memory size to cap used texture memory at 240 MB.
Texture detail is set automatically.
Using picmip 0 on most textures, 1 on normal maps, and 1 on specular maps
Waited 372 msec for asset '$default' of type 'material'.
Waited 36 msec for asset '$additive' of type 'material'.
Waited 0 msec for asset '$line' of type 'material'.
Waited 71 msec for asset 'light_corona' of type 'material'.
Waited 10 msec for asset 'clear_alpha' of type 'material'.
Waited 14 msec for asset 'shadowclear' of type 'material'.
Waited 584 msec for asset 'shadowcaster' of type 'material'.
Waited 10 msec for asset 'stencilshadow' of type 'material'.
Waited 364 msec for asset 'cinematic' of type 'material'.
Error: Waited 458 msec for missing asset "water_droplet".
Error: Could not load material "water_droplet".
Error: Could not load material "water_dynamic_spray".
------- sound system initialization -------
Loading fastfile 'ui'
used 39.48 MB memory in DB alloc
Error during initialization:
Unhandled exception caught
(Mám tento ntb: http://www.alza.cz/hp-probook-4515s-d138752.htm)
To by ještě mělo zvládnout ne?
Edom
Re: Cod 5 error
Příspěvek od Edom »
nic?
strikis
Re: Cod 5 error
Příspěvek od strikis »
Nainstaluj nejnovější ovladače grafické karty
NTB : Lenovo Y570
Intel Core i5-2450M (Sandy Bridge, 2.5GHz, TB až 3.2GHz)
Nvidia GeForce GT555M 2GB
HDD: 750GB / SSD 32GB
RAM : 8GB 1333 MHZ
Windows 7 Ultimate 64-bit OEM :(
tux
Re: Cod 5 error
Příspěvek od tux »
Vrať to kámošovi a kup si vlastní licenci.
Just Fucking Google It!
cobr4in
Re: Cod 5 error
Příspěvek od cobr4in »
A ako porušil licenčné podmienky, tux? V čom je to iné od kúpenia hry z druhej ruky? Sám predsa povedal, že to má iba zapožičané, takže po odskúšaní hru aj s kľúčom vráti kamošovi.
ABBC3_SPOILER_SHOW
  • Win 11 24H2 update na 25H2 error
    od Laces » » v Windows 11, 10, 8...
    10618 Zobrazení
    Poslední příspěvek od Laces
  • Sniper Ghost Warrior 3 CryEngine Error Memory allocation for 4294967295 bytes failed
    od byron » » v Hry
    5706 Zobrazení
    Poslední příspěvek od byron
Zpět na „Hry“
