Logfile of Trend Micro HijackThis v2.0.5
Scan saved at 20:48:30, on 21.10.2014
MSIE: Internet Explorer v11.0 (11.00.9600.17344)
Boot mode: Normal
Running processes:
C:\Program Files (x86)\Skype\Phone\Skype.exe
C:\Users\LUKÁŠ\Downloads\HijackThis.exe
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/fwlink/?LinkId=69157
F2 - REG:system.ini: UserInit=userinit.exe,
O4 - HKLM\..\Run: [Adobe ARM] "C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\AdobeARM.exe"
O4 - HKLM\..\Run: [seznam-listicka-distribuce] "C:\Program Files (x86)\Seznam.cz\distribution\szninstall.exe" -s -d listicka 1 szn-software-listicka cz.seznam.software.autoupdate
O4 - HKCU\..\Run: [DAEMON Tools Lite] "C:\Program Files (x86)\DAEMON Tools Lite\DTLite.exe" -autorun
O4 - HKCU\..\Run: [Sidebar] C:\Program Files\Windows Sidebar\sidebar.exe /autoRun
O4 - HKUS\S-1-5-18\..\RunOnce: [SPReview] "C:\Windows\System32\SPReview\SPReview.exe" /sp:1 /errorfwlink:"http://go.microsoft.com/fwlink/?LinkID=122915" /build:7601 (User 'SYSTEM')
O4 - HKUS\.DEFAULT\..\RunOnce: [SPReview] "C:\Windows\System32\SPReview\SPReview.exe" /sp:1 /errorfwlink:"http://go.microsoft.com/fwlink/?LinkID=122915" /build:7601 (User 'Default user')
O23 - Service: Adobe Acrobat Update Service (AdobeARMservice) - Adobe Systems Incorporated - C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\armsvc.exe
O23 - Service: Adobe Flash Player Update Service (AdobeFlashPlayerUpdateSvc) - Adobe Systems Incorporated - C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
O23 - Service: AppleChargerSrv - Unknown owner - C:\Windows\system32\AppleChargerSrv.exe (file missing)
O23 - Service: Služba Google Update (gupdate) (gupdate) - Google Inc. - C:\Program Files (x86)\Google\Update\GoogleUpdate.exe
O23 - Service: Služba Google Update (gupdatem) (gupdatem) - Google Inc. - C:\Program Files (x86)\Google\Update\GoogleUpdate.exe
O23 - Service: @%SystemRoot%\system32\ieetwcollectorres.dll,-1000 (IEEtwCollectorService) - Unknown owner - C:\Windows\system32\IEEtwCollector.exe (file missing)
O23 - Service: NVIDIA Display Driver Service (nvsvc) - Unknown owner - C:\Windows\system32\nvvsvc.exe (file missing)
O23 - Service: Skype Updater (SkypeUpdate) - Skype Technologies - C:\Program Files (x86)\Skype\Updater\Updater.exe
End of file - 5977 bytes
Prosím o kontrolu pomalý internet Vyřešeno
- lukas polak
- jaro3
- člen Security týmu
Re: Prosím o kontrolu pomalý internet
Stáhni si ATF Cleaner
- Pokud používáš jen Google Chrome , tak ATF nemusíš použít.
Stáhni si TFC
Stáhni AdwCleaner (by Xplode)
http://www.bleepingcomputer.com/download/adwcleaner/
Ulož si ho na svojí plochu
Spusť program poklepáním a klikni na „Prohledat-Scan“
Po skenu se objeví log ( jinak je uložen systémovem disku jako AdwCleaner[R?].txt), jeho obsah sem celý vlož.
- Při instalaci odeber zatržítko u „Povolit bezplatnou zkušební verzi Malwarebytes' Anti-Malware Premium“
Nainstaluj a spusť ho
Aktualizace Malwarebytes' Anti-Malware a Spustit aplikaci Malwarebytes' Anti-Malware, pokud jo tak klikni na tlačítko konec
- pokud bude nalezena aktualizace, tak se stáhne a nainstaluje
- program se po té spustí a klikni na Skenovat nyní a
- po proběhnutí programu se ti objeví hláška vpravo dole tak klikni na b] Kopírovat do schránky [/b]a a vlož sem celý log.
- po té klikni na tlačítko Exit, objeví se ti hláška tak zvol Ano
(zatím nic nemaž!).
Pokud budou problémy , spusť v nouz. režimu.
Stáhni si TFC
(zatím nic nemaž!).
- lukas polak
AdwCleaner v4.001 - Report created 22/10/2014 at 11:00:33
# Updated 20/10/2014 by Xplode
# Database : 2014-10-21.1
# Operating System : Windows 7 Ultimate Service Pack 1 (64 bits)
# Username : LUK�� - LUK��-PC
# Running from : C:\Users\LUK��\Desktop\AdwCleaner.exe
# Option : Scan
***** [ Services ] *****
***** [ Files / Folders ] *****
***** [ Scheduled Tasks ] *****
Task Found : Driver Booster Scan
Task Found : Driver Booster Update
***** [ Shortcuts ] *****
***** [ Registry ] *****
***** [ Browsers ] *****
-\\ Internet Explorer v11.0.9600.17344
-\\ Google Chrome v38.0.2125.104
AdwCleaner[R0].txt - [666 octets] - [22/10/2014 11:00:33]
########## EOF - C:\AdwCleaner\AdwCleaner[R0].txt - [725 octets] ##########
# Option : Scan
- lukas polak
Malwarebytes Anti-Malware
www.malwarebytes.org
Datum skenování: 22.10.2014
Čas skenování: 11:07:29
Protokol: soubor.txt
Správce: Ano
Verze: 2.00.3.1025
Databáze malwaru: v2014.10.22.03
Databáze rootkitů: v2014.10.21.01
Licence: Zkušební verze
Ochrana proti malwaru: Zapnuto
Ochrana proti škodlivým webovým stránkám: Zapnuto
Sebeobrany: Vypnuto
OS: Windows 7 Service Pack 1
CPU: x64
Souborový systém: NTFS
Uživatel: LUKAA
Typ skenu: Sken hrozeb
Výsledek: Dokončeno
Prohledaných objektů: 298467
Uplynulý čas: 10 min, 31 sek
Paměť: Zapnuto
Po spuštění: Zapnuto
Souborový systém: Zapnuto
Archivy: Zapnuto
Rootkity: Vypnuto
Heuristika: Zapnuto
PUP: Zapnuto
PUM: Zapnuto
Procesy: 0
(Žádné zákerné zjištěny položek)
Moduly: 0
Klíče registru: 0
Hodnoty registru: 0
Data registru: 0
Složky: 0
Soubory: 0
Fyzické sektory: 0
(end)
Správce: Ano
Verze: 2.00.3.1025
Sebeobrany: Vypnuto
CPU: x64
Uživatel: LUKAA
Výsledek: Dokončeno
Paměť: Zapnuto
Archivy: Zapnuto
Rootkity: Vypnuto
Heuristika: Zapnuto
PUP: Zapnuto
PUM: Zapnuto
Procesy: 0
Moduly: 0
Klíče registru: 0
Hodnoty registru: 0
Data registru: 0
Složky: 0
Soubory: 0
Fyzické sektory: 0
(end)
- Orcus
Spusť znovu AdwCleaner (u Windows Vista či Windows7, klikni na AdwCleaner pravým a vyber „Spustit jako správce“
Klikni na „ Smazat“
Program provede opravu, po automatickém restartu neukáže log (C:\AdwCleaner [S?].txt) , jeho obsah sem celý vlož.
Stáhni si Junkware Removal Tool
na svojí plochu.
Deaktivuj si svůj antivirový program.
Pravým tl. myši klikni na JRT.exe a vyber „spustit jako správce“. Pro pokračování budeš vyzván ke stisknutí jakékoliv klávesy. Na nějakou klikni.
Stáhni si RogueKiller
32bit.:
http://www.sur-la-toile.com/RogueKiller/RogueKiller.exe
64bit.:
http://www.sur-la-toile.com/RogueKiller ... lerX64.exe
na svojí plochu.
- Pro OS Vista a win7 spusť program RogueKiller.exe jako správce , u XP poklepáním.
- počkej až skončí Prescan -vyhledávání škodlivých procesů.
- Zkontroluj , zda máš zaškrtnuto:
Kontrola MBR
Kontrola Faked
Antirootkit
-Potom klikni na „Prohledat“.
- Program skenuje procesy PC. Po proskenování klikni na „Zpráva“celý obsah logu sem zkopíruj.
Klikni na „ Smazat“
na svojí plochu.
32bit.:
64bit.:
na svojí plochu.
Kontrola MBR
Kontrola Faked
Antirootkit
Pár rad k bezpečnosti PC.
- lukas polak
# AdwCleaner v4.001 - Report created 22/10/2014 at 16:43:30
# DB v2014-10-21.1
# Option : Clean
Task Deleted : Driver Booster Scan
Task Deleted : Driver Booster Update
AdwCleaner[R0].txt - [804 octets] - [22/10/2014 11:00:33]
AdwCleaner[R1].txt - [863 octets] - [22/10/2014 16:41:13]
AdwCleaner[S0].txt - [782 octets] - [22/10/2014 16:43:30]
########## EOF - C:\AdwCleaner\AdwCleaner[S0].txt - [841 octets] ##########
# DB v2014-10-21.1
# Option : Clean
- lukas polak
Junkware Removal Tool (JRT) by Thisisu
Version: 6.3.3 (10.21.2014:1)
OS: Windows 7 Ultimate x64
Ran by LUKµć on st 22.10.2014 at 16:51:59,65
~~~ Services
~~~ Registry Values
~~~ Registry Keys
~~~ Files
~~~ Folders
~~~ Event Viewer Logs were cleared
Scan was completed on st 22.10.2014 at 16:54:34,79
End of JRT log
~~~ Services
~~~ Registry Values
~~~ Registry Keys
~~~ Files
~~~ Folders
End of JRT log
- lukas polak
RogueKiller V10.0.3.0 (x64) [Oct 16 2014] by Adlice Software
mail : http://www.adlice.com/contact/
Feedback : http://forum.adlice.com
Webová stránka : http://www.adlice.com/softwares/roguekiller/
Blog : http://www.adlice.com
Operační systém : Windows 7 (6.1.7601 Service Pack 1) 64 bits version
Spuštěno : Normální režim
Uživatel : LUKÁŠ [Práva správce]
Mód : Prohledat -- Datum : 10/22/2014 17:02:15
¤¤¤ Procesy : 0 ¤¤¤
¤¤¤ Registry : 13 ¤¤¤
[Suspicious.Path] (X64) HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\gdrv (\??\C:\Windows\gdrv.sys) -> Nalezeno
[Suspicious.Path] (X64) HKEY_LOCAL_MACHINE\System\ControlSet001\Services\gdrv (\??\C:\Windows\gdrv.sys) -> Nalezeno
[Suspicious.Path] (X64) HKEY_LOCAL_MACHINE\System\ControlSet002\Services\gdrv (\??\C:\Windows\gdrv.sys) -> Nalezeno
[PUM.Dns] (X64) HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Tcpip\Parameters | DhcpNameServer : 10.0.0.138 -> Nalezeno
[PUM.Dns] (X64) HKEY_LOCAL_MACHINE\System\ControlSet001\Services\Tcpip\Parameters | DhcpNameServer : 10.0.0.138 -> Nalezeno
[PUM.Dns] (X64) HKEY_LOCAL_MACHINE\System\ControlSet002\Services\Tcpip\Parameters | DhcpNameServer : 10.0.0.138 -> Nalezeno
[PUM.Dns] (X64) HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{DA7FEAC3-1B12-4566-ACD1-FCB14543C84B} | DhcpNameServer : 10.0.0.138 -> Nalezeno
[PUM.Dns] (X64) HKEY_LOCAL_MACHINE\System\ControlSet001\Services\Tcpip\Parameters\Interfaces\{DA7FEAC3-1B12-4566-ACD1-FCB14543C84B} | DhcpNameServer : 10.0.0.138 -> Nalezeno
[PUM.Dns] (X64) HKEY_LOCAL_MACHINE\System\ControlSet002\Services\Tcpip\Parameters\Interfaces\{DA7FEAC3-1B12-4566-ACD1-FCB14543C84B} | DhcpNameServer : 10.0.0.138 -> Nalezeno
[PUM.DesktopIcons] (X64) HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\HideDesktopIcons\NewStartPanel | {20D04FE0-3AEA-1069-A2D8-08002B30309D} : 1 -> Nalezeno
[PUM.DesktopIcons] (X64) HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\HideDesktopIcons\NewStartPanel | {59031a47-3f72-44a7-89c5-5595fe6b30ee} : 1 -> Nalezeno
[PUM.DesktopIcons] (X86) HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\HideDesktopIcons\NewStartPanel | {20D04FE0-3AEA-1069-A2D8-08002B30309D} : 1 -> Nalezeno
[PUM.DesktopIcons] (X86) HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\HideDesktopIcons\NewStartPanel | {59031a47-3f72-44a7-89c5-5595fe6b30ee} : 1 -> Nalezeno
¤¤¤ Úlohy : 0 ¤¤¤
¤¤¤ Soubory : 0 ¤¤¤
¤¤¤ Soubor HOSTS : 0 ¤¤¤
¤¤¤ Antirootkit : 0 (Driver: Nahrán) ¤¤¤
¤¤¤ Webové prohlížeče : 0 ¤¤¤
¤¤¤ Kontrola MBR : ¤¤¤
+++++ PhysicalDrive0: ST350041 1SV SCSI Disk Device +++++
--- User ---
[MBR] 7c7c7f98428a0d0abb3f564c31f399f7
[BSP] 8e51039db11256dce4b538081a1ec1ab : Windows Vista/7/8 MBR Code
Partition table:
0 - [ACTIVE] NTFS (0x7) [VISIBLE] Offset (sectors): 2048 | Size: 100 MB
1 - [XXXXXX] NTFS (0x7) [VISIBLE] Offset (sectors): 206848 | Size: 476838 MB
User = LL1 ... OK
Error reading LL2 MBR! ([1] Nesprávná funkce. )
¤¤¤ Procesy : 0 ¤¤¤
¤¤¤ Úlohy : 0 ¤¤¤
¤¤¤ Soubory : 0 ¤¤¤
--- User ---
Partition table:
User = LL1 ... OK
- jaro3
Zavři všechny programy a prohlížeče. Deaktivuj antivir a firewall.
Prosím, odpoj všechny USB (kromě myši s klávesnice) nebo externí disky z počítače před spuštěním tohoto programu.
Spusť znovu RogueKiller ( Pro Windows Vista nebo Windows 7, klepni pravým a vyber "Spustit jako správce", ve Windows XP poklepej ke spuštění).
- Počkej, až Prescan dokončí práci...
- Pak klikni na "Prohledat " ,po jeho skončení:
- V záložkách (Registry , Tasks , Web Browser apod.) vše zatrhni (dej zatržítka)
- Klikni na "Smazat"
- Počkej, dokud Status box nezobrazí " Mazání dokončeno "
- Klikni na "Zpráva " a zkopíruj a vlož obsah té zprávy prosím sem. Log je možno nalézt v RKreport [číslo]. txt na ploše.
- Zavři RogueKiller
Stáhni
Zoek.exe
a uloz si ho na plochu.
Zavři všechny ostatní programy , okna i prohlížeče.
- pozor , náběh programu může trvat déle.
klikni na Run Script
Program provede sken , opravu, sken i oprava může trvat i více minut ,je třeba posečkat do konce. Do okna neklikej!
Po restartu se může nějaký čas ukázat pouze černá plocha , to je normální. Je třeba počkat až se vytvoří log. Ten si můžeš uložit třeba do dokumentů , jinak se sám ukládá do:
C:\zoek-results.log
Zkopíruj sem celý obsah toho logu.
- Zavři RogueKiller
Stáhni
Zoek.exe
Kód: Vybrat vše
autoclean;
emptyclsid;
iedefaults;
FFdefaults;
CHRdefaults;
emptyalltemp;
resethosts;
C:\zoek-results.log
- lukas polak
Mód : Smazat -- Datum : 10/22/2014 19:21:43
¤¤¤ Procesy : 0 ¤¤¤
[Suspicious.Path] (X64) HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\gdrv -> Smazáno
[Suspicious.Path] (X64) HKEY_LOCAL_MACHINE\System\ControlSet001\Services\gdrv -> Smazáno
[Suspicious.Path] (X64) HKEY_LOCAL_MACHINE\System\ControlSet002\Services\gdrv -> Smazáno
[PUM.Dns] (X64) HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Tcpip\Parameters | DhcpNameServer : 10.0.0.138 -> Nahrazeno ()
[PUM.Dns] (X64) HKEY_LOCAL_MACHINE\System\ControlSet001\Services\Tcpip\Parameters | DhcpNameServer : 10.0.0.138 -> Nahrazeno ()
[PUM.Dns] (X64) HKEY_LOCAL_MACHINE\System\ControlSet002\Services\Tcpip\Parameters | DhcpNameServer : 10.0.0.138 -> Nahrazeno ()
[PUM.Dns] (X64) HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{DA7FEAC3-1B12-4566-ACD1-FCB14543C84B} | DhcpNameServer : 10.0.0.138 -> Nahrazeno ()
[PUM.Dns] (X64) HKEY_LOCAL_MACHINE\System\ControlSet001\Services\Tcpip\Parameters\Interfaces\{DA7FEAC3-1B12-4566-ACD1-FCB14543C84B} | DhcpNameServer : 10.0.0.138 -> Nahrazeno ()
[PUM.Dns] (X64) HKEY_LOCAL_MACHINE\System\ControlSet002\Services\Tcpip\Parameters\Interfaces\{DA7FEAC3-1B12-4566-ACD1-FCB14543C84B} | DhcpNameServer : 10.0.0.138 -> Nahrazeno ()
[PUM.DesktopIcons] (X64) HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\HideDesktopIcons\NewStartPanel | {20D04FE0-3AEA-1069-A2D8-08002B30309D} : 1 -> Nahrazeno (0)
[PUM.DesktopIcons] (X64) HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\HideDesktopIcons\NewStartPanel | {59031a47-3f72-44a7-89c5-5595fe6b30ee} : 1 -> Nahrazeno (0)
[PUM.DesktopIcons] (X86) HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\HideDesktopIcons\NewStartPanel | {20D04FE0-3AEA-1069-A2D8-08002B30309D} : 1 -> Nahrazeno (0)
[PUM.DesktopIcons] (X86) HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\HideDesktopIcons\NewStartPanel | {59031a47-3f72-44a7-89c5-5595fe6b30ee} : 1 -> Nahrazeno (0)
¤¤¤ Úlohy : 0 ¤¤¤
¤¤¤ Soubory : 0 ¤¤¤
--- User ---
Partition table:
User = LL1 ... OK
RKreport_SCN_10222014_170215.log - RKreport_SCN_10222014_192057.log
¤¤¤ Procesy : 0 ¤¤¤
¤¤¤ Úlohy : 0 ¤¤¤
¤¤¤ Soubory : 0 ¤¤¤
--- User ---
Partition table:
User = LL1 ... OK
- lukas polak
Zoek.exe v5.0.0.0 Updated 19-10-2014
Tool run by LUKµć on st 22.10.2014 at 19:25:52,09.
Microsoft Windows 7 Ultimate 6.1.7601 Service Pack 1 x64
Running in: Normal Mode Internet Access Detected
Launched: C:\Users\LUK~1\Desktop\zoek.scr [Scan all users] [Script inserted]
==== System Restore Info ======================
22.10.2014 19:26:30 Zoek.exe System Restore Point Created Succesfully.
==== Reset Hosts File ======================
# Copyright (c) 1993-2006 Microsoft Corp.
# space.
# lines or following the machine name denoted by a '#' symbol.
# For example:
# localhost name resolution is handle within DNS itself.
127.0.0.1 localhost
::1 localhost
==== Deleting CLSID Registry Keys ======================
==== Deleting CLSID Registry Values ======================
==== Deleting Services ======================
==== Chromium Look ======================
==== Set IE to Default ======================
Old Values:
[HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main]
"Start Page"="http://go.microsoft.com/fwlink/?LinkId=69157"
[HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\SearchScopes]
No DefaultScope Set For HKCU
New Values:
"DefaultScope"="{012E1000-F331-11DB-8314-0800200C9A66}"
==== All HKCU SearchScopes ======================
{012E1000-F331-11DB-8314-0800200C9A66} Google Url="http://www.google.com/search?q={searchTerms}"
{0633EE93-D776-472f-A0FF-E1416B8B2E3A} Bing Url="http://www.bing.com/search?q={searchTerms}&src=IE-SearchBox&FORM=IE8SRC"
{C913D6FF-638C-4205-B97B-6C3391340144} Seznam TV Program Url="http://tv.seznam.cz/hledej?w={searchTerms}&sourceid=QuickSearch_13415"
==== Reset Google Chrome ======================
C:\Users\LUK~1\AppData\Local\Google\Chrome\User Data\Default\Preferences was reset successfully
C:\Users\LUK~1\AppData\Local\Google\Chrome\User Data\Default\Web Data was reset successfully
==== Empty IE Cache ======================
C:\Windows\system32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5 emptied successfully
C:\Windows\SysNative\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5 emptied successfully
C:\Windows\serviceprofiles\networkservice\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5 emptied successfully
C:\Windows\serviceprofiles\Localservice\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5 emptied successfully
C:\Users\LUK~1\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\1NL5SWPS will be deleted at reboot
C:\Users\LUK~1\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\VDUUDBLJ will be deleted at reboot
==== Empty FireFox Cache ======================
No FireFox Profiles found
==== Empty Chrome Cache ======================
C:\Users\LUK~1\AppData\Local\Google\Chrome\User Data\Default\Cache emptied successfully
==== Empty All Flash Cache ======================
Flash Cache Emptied Successfully
==== Empty All Java Cache ======================
No Java Cache Found
==== C:\zoek_backup content ======================
C:\zoek_backup (files=0 folders=0 0 bytes)
==== Empty Temp Folders ======================
C:\Users\Default\AppData\Local\Temp emptied successfully
C:\Users\Default User\AppData\Local\Temp emptied successfully
C:\Users\LUK~1\AppData\Local\Temp will be emptied at reboot
C:\Windows\serviceprofiles\networkservice\AppData\Local\Temp emptied successfully
C:\Windows\serviceprofiles\Localservice\AppData\Local\Temp emptied successfully
C:\Windows\Temp will be emptied at reboot
==== After Reboot ======================
C:\Windows\Temp successfully emptied
C:\Users\LUK~1\AppData\Local\Temp successfully emptied
==== Empty Recycle Bin ======================
C:\$RECYCLE.BIN successfully emptied
==== Deleting Files / Folders ======================
"C:\Users\LUK~1\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\1NL5SWPS" not found
"C:\Users\LUK~1\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\VDUUDBLJ" not found
==== EOF on st 22.10.2014 at 19:38:04,22 ======================
# space.
# For example:
127.0.0.1 localhost
::1 localhost
Old Values:
New Values:
No Java Cache Found
- Orcus
Co problémy?
