Zdar, dneska jsem si z nového kompu hodil do starého Minecraft aby jsem mohl pařit i v noci. Ale objevil se problém když se přihlásím skočí tam tento log, nevíte pls co my říká?
Bad video card drivers!
Minecraft was unable to start because it failed to find an accelerated OpenGL mode.
This can usually be fixed by updating the video card drivers.
--- BEGIN ERROR REPORT 7fe0271 --------
Generated 4.5.12 16:21
Minecraft: Minecraft 1.2.5
OS: Windows XP (x86) version 5.1
Java: 1.6.0_31, Sun Microsystems Inc.
VM: Java HotSpot(TM) Client VM (mixed mode), Sun Microsystems Inc.
LWJGL: 2.4.2
[failed to get system properties (java.lang.NullPointerException)]
org.lwjgl.LWJGLException: Pixel format not accelerated
at org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelFormat(Native Method)
at org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat(WindowsPeerInfo.java:52)
at org.lwjgl.opengl.WindowsDisplay.createWindow(WindowsDisplay.java:185)
at org.lwjgl.opengl.Display.createWindow(Display.java:311)
at org.lwjgl.opengl.Display.create(Display.java:856)
at org.lwjgl.opengl.Display.create(Display.java:784)
at org.lwjgl.opengl.Display.create(Display.java:765)
at net.minecraft.client.Minecraft.a(SourceFile:236)
at net.minecraft.client.Minecraft.run(SourceFile:657)
at java.lang.Thread.run(Unknown Source)
--- END ERROR REPORT 4fa887ad ----------
Minecraft log Vyřešeno
- Scanner
- Level 3.5
Minecraft log
When You smoke herb it reveals you to yourself. All the wickedness you do is revealed by the herb - it's you conscience and gives you an honest picture of yourself.
---------- Robert Nesta Marley ----------
Re: Minecraft log
Copak je takovej problém si ten text přečíst?!
Nebo použít Google a najít dalších 116 milionů stejnejch problémů?
Just Fucking Google It!
- Andrew98
- Level 5.5
Re: Minecraft log
stáhni nové ovladače grafiky
ASUS B85-PRO GAMER
Sapphire R9 270X Toxic Boost
Seasonic SS-620GM2 Evo 620W
iiyama ProLite X2483HSU-B1
ASUS B85-PRO GAMER
- Scanner
- Level 3.5
Re: Minecraft log Vyřešeno
Díky moc hned to zkusím.
- 1490
od nl635
25 lis 2023 19:09
- 2305
od michal84
07 črc 2023 10:52
