již druhý den mě trápí jeden problém. A ten je, že se na chvíli spustí minecraft je jen černý nic neukazuje a po 5 sekundách se vypne. Tak to jde pořád dokola. Problém začal z ničeho nic.
Tohle mi to píše v launcheru.
Mám přidané dva módy a ty jsou OptiFine a ShadersMod. Normální minecraft není graficky moc pěkný.
[16:47:47] [main/INFO]: Loading tweak class name optifine.OptiFineTweaker
[16:47:47] [main/INFO]: Using primary tweak class name optifine.OptiFineTweaker
[16:47:47] [main/INFO]: Loading tweak class name shadersmodcore.loading.SMCTweaker
[16:47:47] [main/INFO]: Calling tweak class optifine.OptiFineTweaker
OptiFineTweaker: acceptOptions
OptiFineTweaker: injectIntoClassLoader skipped, OptiFine is loaded as a library
[16:47:47] [main/INFO]: Calling tweak class shadersmodcore.loading.SMCTweaker
OptiFineTweaker: getLaunchArguments
OptiFineTweaker: getLaunchTarget
[16:47:47] [main/INFO]: Launching wrapped minecraft {net.minecraft.client.main.Main}
[SMC FNE]transforming azl azl
[SMC FNE] 48395 (+59)
[16:47:47] [main/INFO]: Setting user: pepanecek5
[16:47:47] [main/INFO]: (Session ID is token:240a4c5ba4aa465b9d09c9925763a047:404990cfdf7b476e9cb7b17e6919fd6d)
[SMC FNE]transforming aif aif
[SMC FNE] 28808 (+0)
[SMC FNE]transforming aae aae
[SMC FNE] 2482 (+0)
[16:47:47] [Client thread/INFO]: LWJGL Version: 2.9.1
[SMC FNE]transforming bwq bwq
[SMC FNT] set activeTexUnit
[SMC FNE] 13474 (+65)
[OptiFine]
[OptiFine] OptiFine_1.7.5_HD_U_D1
[OptiFine] Wed Oct 22 16:47:48 CEST 2014
[OptiFine] OS: Windows 7 (amd64) version 6.1
[OptiFine] Java: 1.7.0_67, Oracle Corporation
[OptiFine] VM: Java HotSpot(TM) 64-Bit Server VM (mixed mode), Oracle Corporation
[OptiFine] LWJGL: 2.9.1
[OptiFine] OpenGL: ASUS R9 280 Series version 4.4.13084 Compatibility Profile Context 14.301.1004.0, ATI Technologies Inc.
[OptiFine] OpenGL Version: 4.0
[OptiFine] OpenGL Fancy fog: Not available (GL_NV_fog_distance)
[OptiFine] Maximum texture size: 16384x16384
[OptiFine] Checking for new version
[SMC FNE]transforming bqp bqp
[SMC FNE] 912 (+136)
[SMC FNE]transforming bqo bqo
[SMC FNE] 714 (+276)
[SMC FNE]transforming brg brg
[SMC FNE] 180 (+63)
[SMC FNE]transforming bqy bqy
[SMC FNT] loadRes
[SMC FNT] loadRes
[SMC FNT] allocateTextureMap
[SMC FNT] setSprite setIconName
[SMC FNT] uploadTexSubForLoadAtlas
[SMC FNE] 18066 (+458)
[OptiFine] Version found: D1
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x0000000056bd25d5, pid=1380, tid=5148
# JRE version: Java(TM) SE Runtime Environment (7.0_67-b01) (build 1.7.0_67-b01)
# Java VM: Java HotSpot(TM) 64-Bit Server VM (24.65-b04 mixed mode windows-amd64 compressed oops)
# Problematic frame:
# C [atio6axx.dll+0xdd25d5]
# Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
# An error report file with more information is saved as:
# C:\Users\Šůstkovi\AppData\Roaming\.minecraft\hs_err_pid1380.log
# If you would like to submit a bug report, please visit:
# http://bugreport.sun.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
Minecraft se nezapne
- pepanecek5
- Level 3.5
Moje železo
Deska - ASUS ROG STRIX B560-E Gaming
CPU - Intel Core i7 11700K
RAM - Kingston Fury Beast RGB 32GB
CHLADIČ - Arctic Liquid Freezer II 280
GRAFIKA - ASUS Gefroce GTX 1660
SKŘÍŇ - CoolerMaster HAF 922
ZDROJ - Seasonic Focus+ 750W
- Karrex
- Elite Level 10
Re: Minecraft se nezapne
Když odstraníš módy, funguje?
- pepanecek5
- Level 3.5
Ano, ale bez módů se mi moc nechce hrát. Zkoušel jsem i reinstalovat total celý minecraft, ale nepomohlo.
Moje železo
Jak instaluješ módy a na jaké verzi hraješ ? Je třeba minecraft.jar souboru (.minecraft/bin) prvně vložit modloader (hlavně verzi udělanou na tvojí verzi mc) a pak vymazat Meta-inf. Pokud si mody dáváš do minecraft.jar tak je přesouvej do složky .minecraft/mods ... pokud i to nepomůže, tak hledej pomoc na googlu, nejsi první ani poslední.
- pepanecek5
- Level 3.5
Jsou to instalátory. Předtím to šlo, ale když jsem nainstaloval nový ovladač na grafiku tak s ním začaly problémy. Ovladač jsem třikrát přeinstaloval a zkoušel i jiné verze, ale pořád nic.
Moje železo
- Karrex
- Elite Level 10
Javu máš aktuální?
- pepanecek5
- Level 3.5
Javu jsem měl verzi 7 a build 40. Ona už byla java 8 build 25 ale pořád to nejde a teď to napsalo něco jiného zase.
[20:12:13] [main/INFO]: Loading tweak class name optifine.OptiFineTweaker
[20:12:13] [main/INFO]: Using primary tweak class name optifine.OptiFineTweaker
[20:12:13] [main/INFO]: Loading tweak class name shadersmodcore.loading.SMCTweaker
[20:12:13] [main/INFO]: Calling tweak class optifine.OptiFineTweaker
[20:12:13] [main/INFO]: Calling tweak class shadersmodcore.loading.SMCTweaker
[20:12:13] [main/INFO]: Launching wrapped minecraft {net.minecraft.client.main.Main}
[20:12:13] [main/INFO]: Setting user: pepanecek5
[20:12:13] [main/INFO]: (Session ID is token:240a4c5ba4aa465b9d09c9925763a047:404990cfdf7b476e9cb7b17e6919fd6d)
[SMC FNE] 2482 (+0)
[20:12:13] [Client thread/INFO]: LWJGL Version: 2.9.1
[OptiFine]
[OptiFine] Wed Oct 22 20:12:14 CEST 2014
[OptiFine] OS: Windows 7 (x86) version 6.1
[OptiFine] Java: 1.8.0_25, Oracle Corporation
[OptiFine] VM: Java HotSpot(TM) Client VM (mixed mode), Oracle Corporation
[OptiFine] Maximum texture size: 8192x8192
[SMC FNE] 180 (+63)
[SMC FNT] loadRes
[SMC FNT] loadRes
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x55fc5c77, pid=7112, tid=896
# JRE version: Java(TM) SE Runtime Environment (8.0_25-b18) (build 1.8.0_25-b18)
# Java VM: Java HotSpot(TM) Client VM (25.25-b02 mixed mode windows-x86 )
# C [atioglxx.dll+0xc35c77]
# C:\Users\Šůstkovi\AppData\Roaming\.minecraft\hs_err_pid7112.log
Java HotSpot(TM) Client VM warning: Using incremental CMS is deprecated and will likely be removed in a future release
[SMC FNE] 2482 (+0)
[OptiFine]
[SMC FNE] 180 (+63)
[SMC FNT] loadRes
[SMC FNT] loadRes
Moje železo
- Karrex
- Elite Level 10
Nemáš náhodou 14.9.1 BETA ovladače grafiky? Kód 14.301.1004.0 by tomu nasvědčoval. Odinstaluj to a nainstaluj poslední verzi, ale ne BETU, tedy 14.9.
Když byla ještě 14.9 BETA, tak mi s ní taky nešel Minecraft.
- pepanecek5
- Level 3.5
Na verzi 14.9 to pořád nešlo, tak jsem stáhl verzi 13.9 a ejhle ono to jede ! Díky
Moje železo
- Karrex
- Elite Level 10
Zkus alespoň stáhnout 14.5 nebo 7, teď nevím jaká verze byla před 14.9.
- 1246
od Grander
17 lis 2023 11:49
- 1503
od nl635
25 lis 2023 19:09
- 2331
od michal84
07 črc 2023 10:52
